will lowered springs change pinion angle?
Old Nov 6, 2000 | 02:06 PM
FormulaGod's Avatar
I want to order eibach lowering springs, but im concerned if they will change the pinion angle noticibly. Is this true?
"Ever notice how imports sound like weedwackers"
Old Nov 6, 2000 | 11:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Pinion angle can't really change because the torque arm holds it in line to the transmission.
Pinion angle is really ony a concern when lifting a truck over 3-4" on the suspension,, you're only going down about an inch
New website home
**The ****** at Anzwers.org deleted all of my files w/o notice**
- 4 out of 5 people think the 5th is an idiot
Old Nov 7, 2000 | 10:04 AM
SteveSpohn's Avatar
The torque arm is mounted to the transmission, the transmission is mounted to the body. You lower the body 1"-2" = you lower the transmission 1"-2". The answer is yes, it changes your pinion angle.
It also alters the LCA angles as well. It also alters the centering of the rear since the panhard bar is fixed length, it will kick your rear off to the side.
The solutions are:
Pinion Angle: Adjustable Torque Arm
LCA Angles: LCA Relocation Brackets
Rear Centered: Adjustable Panhard Bar
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
TA8487
Aug 11, 2015 09:02 PM
