Is it absolutely necessary to get an alignment after replacing front struts?
Old Nov 8, 2000 | 10:56 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I just replaced the struts on my car. After doing this, I read that you need to take it to an alignment shop after replacing them. Is this absolutely necessary? I have driven probably about 200 miles since then including about 150 miles from Atlanta to Clemson at about 90 mph with no problems. i can't feel any problems with the alignment or steering.
1991 Z28 - 350 TPI, T56, Centerforce Dual Friction clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old Nov 8, 2000 | 01:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The idea rises from the fact that the car was probably aligned at some point in time with worn-out struts. Since our cars use the Macpherson strut design, with no upper control arm, the strut's position affects caster & camber.
Like you experienced, it might not be drastically enough, hell, you might not even feel a difference. I guess you could tell by checking out the tire wear pattern.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 8, 2000 | 04:26 PM
ede's Avatar
ede
i don't think you'd change any thing unless you moved the strut bearing. never the less i'd have it done just to be on the safe side.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 8, 2000 | 05:10 PM
82camaro's Avatar
Car: 82 camaro SC
If it's been more than a year since your last alignment, chances are you need an alignment anyway.
If it was aligned with the worn out struts, your alignment will be a little off. Also, the strut specs vary from one brand to another and some have a little play in the bottom holes. I would do it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Nov 9, 2000 | 09:07 AM
scauffiel's Avatar
Do what I did and go get yourself a Lifetime Alignment. Yeah, it'll cost ya about $100 but I go in every other month to make sure my crap is good to go. You ever wonder why we can put men into space but we can't get smooth roads? Makes me nuts...
Steve
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
