Gear Identification
Old Nov 16, 2000 | 12:55 PM
Neo's Avatar
Neo
Gear Identification
How can you tell what gear ratio you have by looking?
And then what was stock on a '91 RS?
Old Nov 16, 2000 | 05:25 PM
Ron Mullins's Avatar
Neo, Look in the glove box between the seats. There should be a code GU and a number. I'm pretty sure these are the codes:
GU2 = 2.73
GU4 = 3.23
GU5 = 3.42
GU6 = 3.73
I don't know what the stock gear was.
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Nov 16, 2000 | 06:48 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
91 RS with a TBI, automatic trans has an open 2.73 gear, 5-speed is an open 3.08 gear. For 6-cyls, I dont know.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 17, 2000 | 03:49 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's also an axle ID number stamped on the "front" of the passenger side axle tube. It'll take some soap, wire brushing and a wet sponge to see the #'s, if they haven't rusted away already. It's a long code, three letters of which are the ratio and posi info. The Haynes 82-92 Camaro/Firebird manual lists these codes for all years. The GM service manual lists the codes only for the year the GM book covers. If you don't have either book, and can't find the RPO code sheet, put that code # up here and we can try to look it up.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 17, 2000 | 06:51 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I have the GU5 code on my 85Z LG4 5 speed. Does this mean I have 3.42 gears or are the codes different for different years. I had thought that LG4 5 speeds came with 3.08 rear ends. If anybody has any ideas let me know. Thanks
Old Nov 18, 2000 | 02:15 AM
Kevin91Z's Avatar
Ron, just a little off:
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
Troy, you've got 3.23's and thats perfectly normal for carb'd cars.
Old Nov 20, 2000 | 10:19 AM
Neo's Avatar
Neo
Thanks for the help!!
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube in back
Future: 2" Cowl hood w/ K&N filter
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
