Brakes?
Old Nov 16, 2000 | 02:24 PM
Hulk0202's Avatar
Brakes?
When I push the brake pedal, I hear a loud click that seems to be coming from the rear. I origanally thought it waqs one of my front calipers, but I replaced everything up front and its still there. I ruled out suspension from the car rocking forward when braking because it will make the noise if I step on the brake just enough to feel a little tension, without the car really slowing down any. I'm, rebuilding the back brakes this weekend, will this fix it?
Old Nov 18, 2000 | 02:51 AM
92b4c's Avatar
i had this same problem on one of my front brakes i found that the pad was sliding around inside the caliper and making the loud noise when i bearly even touched the pedal if you change the pads that should take care of it. it took me 3 months to figure mine out so good luck
92 b4c 305 t-5
ported plenum
58mm TB
dynomax headers
msd coil
adjustable fuel regulator
air foil
K&N
TB coolant bypass
smog pump bypass
worldclass t-5
custom built y pipe
hi-flow cats
flowmaster
hurst shifter
3.73 rear
Old Nov 20, 2000 | 07:59 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I have had the same problem before. I bought OEM GM calipers which are vinyl-backed and the problem went away.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Nov 20, 2000 | 04:49 PM
ede's Avatar
ede
moving to the brakes board, you should find more help there.
-=ICON MOTORSPORTS=-
1st & 3rd
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
