Coilover or no to Coilover
Old Apr 14, 2010 | 08:15 PM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Well I'm debating what to do for 87 IROC with a Turboed 370 LSX/ T56. Its mostly a street car with some drag strip use. I run 18x9s in the fron. I've seen Spohn and BMR make coil over kits. Would these be ideal? i want to drop the car about 2" all the way around. Any advice would be great.
Old Apr 14, 2010 | 09:21 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Coilover or no to Coilover
You will lose strut to tire clearance. With your wide front wheels, there may be a clearance issue.
Old Apr 15, 2010 | 04:57 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
so were do you find weight jacks???
Old Apr 15, 2010 | 09:45 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Ground control sells a drop in kit for our cars. or, you can go with something like this.
The latter setup will require a little work to install.
Old Apr 17, 2010 | 08:48 PM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Im going to get the ground control kit. Thanks guys
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
darwinprice
17
Oct 11, 2015 11:51 PM
C Murda
Oct 24, 2005 08:34 PM
DuronClocker
Mar 9, 2005 01:30 AM
ME Leigh
Nov 10, 2004 01:00 PM
