What broke...
Old Apr 15, 2010 | 07:26 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
What broke...
Ok heres the deal, my project maro has been sitting pretty much stationary since I got it, for about 6 months, and whole time its sat there perfectly normal stance, and even ground clearance all around and what not. Then yesterday I notice that half my back left tire is behind my fender, ie. the car is sitting low as hell on just that corner.....the wierd thing is the car hasn't been driving around so I can't see how something would break like that, only thing I can think of is I tried moving it with my other car, and had it on a jack on the left side....but neither one of those things should damage a car.
I'm guessing shock or spring?
Old Apr 16, 2010 | 09:28 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: What broke...
Possibly spring. I can't see why it would have broke or anything, though. The shock doesn't hold the car up so, it wouldn't be that. Maybe the spring perch broke on the axle?
Old Apr 16, 2010 | 10:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: What broke...
A visual will probably tell you what you need to know.
JamesC
Old Apr 16, 2010 | 01:43 PM
Engine: 3.8, 3.4
Re: What broke...
That's what dave suggested, I'll have to jack it up some and try to get a peak...problem is idk how I'm going to fix it, cause the car is on a hill atm, so I can't work under it. Anything in particular I should be looking for? And Idk if this helps diagnose it at all, but the lca on that side is angled up instead of the normal down angle it should be at, which to me suggests spring issue.
Old Apr 16, 2010 | 11:02 PM
Car: 91 Camaro
Re: What broke...
that lca is angled because the axle is still in its normal position (relative to the ground) but the chassis is "on the ground". You'll just have to look under it to see. You can probably tell from the back of the car.
Z28'83
Dec 11, 2012 10:00 PM
88Camaro1993
Interior Parts Wanted
Apr 20, 2012 09:50 AM
Bullydawg
Northern California
16
Mar 25, 2011 03:39 PM
87blackz28
Dec 23, 2010 03:07 PM
jbucago
Jan 12, 2010 07:56 PM
