Northern California Discussion board for Northern and Central California.
First Start-up!
Old Mar 14, 2011 | 12:47 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
First Start-up!
Well, I started it and it ran rough, so I adjusted the timing, and warmed it up a bit and it was running good.... But there was a squeal, so I looked at the belt and my buddy put it on too tight, so I loosened it... same noise. So I was like meh... then I was like this isn't right. Shut it off, and check out the belt and it was smoking. So I touched it and it was hot, then pop... my NEW belt broke... Which wasn't too bad I guess until I realized it broke because my Smog Pump and magically seized, and because of that, the belt got hot and took out my AC delete pulley, so I now I have to order a new pulley which will take a while to get here... And I am going to buy a new smog pump and belt tomorrow.
Well, thats my rant... Can't even start to break in my car... grr
Old Mar 14, 2011 | 01:28 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: First Start-up!
video?
Old Mar 14, 2011 | 10:50 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: First Start-up!
You can get a dorman AC delete at oreillys usually. If I get time ill look up a part# for you. Otherwise you should be able to go down there and get their book and figure it out. And don't u just hate how nothing ever goes smoothly?!
Old Mar 14, 2011 | 12:14 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: First Start-up!
Got that sucker ready to-go pretty quick though!
Remind us all again what you've recently swapped into to your Formy??
Old Mar 14, 2011 | 01:08 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: First Start-up!
At least it fired up relatively quickly.. glad to hear its runnin again. Got any pics or vids?
Old Mar 14, 2011 | 02:29 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: First Start-up!
I do have a vid of the first start with the screach ill post up...
And del, I just rebuilt the 350 with forged pistons and added a 268 xfi cam... going from I think .470 lift to .540...
Old Mar 14, 2011 | 02:31 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: First Start-up!
Damn, I just ordered one from ebay. Shoot. Ill give them a call and check though.
I decided for now I am going to throw the ac unit on, with nothing hooked up and just use it for the pulley.
Old Mar 14, 2011 | 03:00 PM
Car: '89 GTA
Re: First Start-up!
Oh okay, the 350 you were selling at one point. Cool! You'll like that XFI and maybe see some 12's!
Old Mar 14, 2011 | 10:19 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: First Start-up!
sounds like you got it worked out. I tried to get that in as soon as possible, sorry. When you get her fired up again get a video on here for us!
Old Mar 15, 2011 | 12:25 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: First Start-up!
So far today I've put 70 miles on her with no problems. Ill be taking a cruise to sac in afew days to put some miles on her... I'm hoping I can run it at the track on Saturday pending the weather.
Old Mar 15, 2011 | 11:17 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: First Start-up!
Good to hear A-Rod, hope all is well bro
Old Mar 16, 2011 | 03:27 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: First Start-up!
Dumping fuel now and no start. What's going on... its like an instant flood and won't start. Has spark, air, and too much fuel. WAY too much fuel.
Old Mar 16, 2011 | 03:51 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: First Start-up!
bad MAF maybe, or leaking injectors?
Old Mar 16, 2011 | 09:03 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: First Start-up!
Fuel pressure regulator bad and fuel is being bypassed? Im not TPI guru so I may be totally wrong. improper working Coolant temp sensor telling the engine the wrong temperature so maybe its dumping gas because of that.
Old Mar 24, 2011 | 11:16 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: First Start-up!
Okay, here are the video's...
First Startup
The Second Startup was the same pretty much, but it shredded my new belt and tore up my AC Delete pulley because of a seized smog pump... no clip...
Third Startup with new belt and the ac pulley put back in as a temp
And here is the first drive... Fun Stuff... haha
Old Mar 24, 2011 | 10:14 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: First Start-up!
Good time to run out of gas
Ask me how I know firsthand that these cars are incredibly hard to push uphill
Old Mar 25, 2011 | 03:39 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: First Start-up!
Haha yeah. That was where I was heading... when I pulled the car in the garage to pull the engine it was cutting out. So I knew it was going to be a pinch.
89Z
Mar 19, 2006 09:51 PM
vernw
Mar 1, 2006 12:54 PM
SeanTimothy
Sep 7, 2003 01:49 PM
Thunderboy
Feb 14, 2003 12:38 PM
