can't diconnect strut from steering knuckle. HELP!
Old Dec 4, 2000 | 11:09 AM
woody86's Avatar
i tried to change my front struts and i can't get out the bolt that holds the strut to the steering knuckle. i got the nuts (i said nuts) off of the bolts, i just can't get the bolts out. i tried an impact gun, an air chisle, a sledge hammer, and even broke a 1/2in breaker bar. any suggestions?
Old Dec 4, 2000 | 04:45 PM
ede's Avatar
ede
i put the nuts back on enough to protect the threads and used a BFH. still messed up a nut (i said nut too) or two. after i got the bolt started i used a drift punch to drive it the rest of the way out.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 10, 2000 | 11:04 AM
OLDYELLR's Avatar
Car: '85 IROC
Same thing! I still ended up with distorted threads and it took a lot of torque to get the nuts back on one side. Ideally, you should have new nuts and bolts.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Dec 11, 2000 | 12:05 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I don't know why it was so hard for you guys. I did mine recently and was able to get the bolts out just by tapping them with a hammer. Try shaking around the spindle and maybe that will break loose the strut and the bolts. You've probably already done that so I guess I don't have any real help for you. Sorry
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old Dec 11, 2000 | 05:02 AM
quartermileguy's Avatar
use the all mighty FLAME WRENCH!!!!!!!!!!!
heat it up and it should twist right out.....
or 'shock' it; heat it up and pour water on it to expand and contract the metal quickly..
also i'm a BIG fan or PB Blaster.....best penetrating oil out there......
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
