HELP.....How do I disconnect the ebrake cable from a drum rear
Old Dec 15, 2000 | 07:37 PM
irocbsa's Avatar
I am in the process right now of doing a drum rear swap and have gotten everything disconnected except the ebrake cable. It says nothing about it in the Haynes manual. The haynes manual also skipped over a few important steps in removing the rear end, such as remove the track bar. I'm really losing faith in the Haynes..........
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Dec 15, 2000 | 08:34 PM
ede's Avatar
ede
i'll sort of guess at it. it's been a while since i was under a thirdgen with a e brake. with the brake off ,there should be an adjustment under the car. loosen it to create slack in the cable. the cable from the drum goes to a coupler sort of thing. twist and angle the coupler untill you get the round thing on the end of the cable to go thru the hole and loose from the coupler. if i'm wrong flame away, i said i'd guess at it. it should be easy for you to figure out if you looked and got under the car. i took all my e brake assembly out last summer. sorry i just used a grinder and cut it out.
ICON Motorsports
1st & 3rd
Old Dec 15, 2000 | 08:55 PM
irocbsa's Avatar
OK, I got it. Right after I posted I went back and looked at it again and did it in about the same way you said. Thanks.
bsa
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
3rdgenparts
Aug 6, 2015 09:03 AM
