master cyl run dry.....
Old Dec 17, 2000 | 05:39 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i have let my rear resevoir run dry , changing my rear out again, and need to know what the disadvantages of leaving the brake line open are??? I know the dirt and moisture but is there any permanent harm to the braking system. I would rather not have to keep bleeding these things since the car is gonna sit till the rear gets rebuilt.
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Dec 17, 2000 | 05:45 PM
ede's Avatar
ede
you should be able to find something at a parts store that would let you screw on the flare nuts so you can close the system. do a gravity bleed and cap it. allowing any thing in the system is bad. if you leave it open for a long time the more chances you have for problems. that said i've left lines open for months with nothing bad happening.
ICON Motorsports
1st & 3rd
Old Dec 17, 2000 | 10:31 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
a nut and bolt with washers would work,right?,I left mine open for a while once,no damage,but better to be safe than.....totally screwed when your rear brakes give out.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
fasteddi
Sep 2, 2015 10:29 AM
KO1
Aug 31, 2015 06:31 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
