Which way should the rear springs be facing?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I installed the jamex lowering kit and I was wondering which way the rear springs should be facing?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Small end down.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Car: 86 Z28
CAn you please explain a little more, should the cut part of the spring be facing forward? what do you mean by small end? thanks
I don't understand what you are trying to do exactly. Do you want to know which way the tangential (only touches in one spot) cut end on the top of the rear spring is oriented? It should fit into the rear isolator (rubber thing). The isolator is flat on top and requires no specific orientation. The bottom of the rear spring is a small pigtail and it does not matter which way it is facing.
I hope you don't mean the front springs. They can be confusing. The tangential end goes down on the front spring and spins into the lower control arm to a specific spot between two drain holes.
[This message has been edited by CamaroMike (edited December 17, 2000).]
Car: 86 Z28
I mean the rear springs, I heard the cut part on the bottom of the spring should be facing a certain way.
NOPE!
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
