moog replacement springs
Old Apr 22, 2010 | 09:17 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
hey guys
was wondering if these would be a great replacement for my worn out old stock springs.. dont really care for performance just wanna replace the rusty tired springs...
front springs
http://www.spohn.net/shop/1982-1992-...ings-Pair.html
back springs
i dont want to get lowering springs because my exhuast setup is already low enough and scrapes at times being that i have long tube headers....
Old Apr 22, 2010 | 09:21 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Re: moog replacement springs
i have the same exact question, im gonna do a search but i will keep an eye on this thread
Old Apr 22, 2010 | 10:17 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Check in my sig those are the exact ones I installed on my car... They raised the car quite a bit but i prefer it this way in the sense that it still handles good and i can drive it without scraping anything and actually enjoy the car.. although i might lower it with drop spindles (the right way!) next year... I like it like this though.. You will need an alignment after installing them but they are really stiff and provide a nice ride with my tokico blue shocks/struts.
Old Apr 22, 2010 | 11:04 PM
88fastgta's Avatar
the moog springs... how much higher are they from stock.... i wouldnt mind it being raised a little bit to help with exhaust clearance... did your handling or anything suffered with these springs.... how is the ride..
Old Apr 23, 2010 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've read, but never been able to verify, that OE ride height is 27 1/2". My car with the Moog fronts sits at 26 3/4". The Moog rears had the car jacked up to a ridiculous height, IMO. So I first removed the OE insulator and replaced it with radiator hose, then cut a bit of coil. Long story short, I was forced to cut a second time. The car currently sits at 27". Moog calls them stock replacements, but....
JamesC
Old Apr 23, 2010 | 11:56 AM
The rear sits higher than the front and the car all around is ALOT higher than I had with my stock sagging springs.. Still, I would like to lower it some but it rides great i have to say, stiffer but it feels like it takes the bumps alot better. There is a slight rake on the car. It's at the garage right now but as soon as I get it back and fixed i'll be able to tell you how high it is from the ground and i'll measure fender gap too. I also put in 4th gen isolators which are a bit thicker so they would be a bit lower with 3rd gen ones which aren't as thick... All in all it was a good purchase but I will probably install 2" drop spindles next season when the budget permits
Old Apr 23, 2010 | 12:00 PM
88fastgta's Avatar
well i still will get them.... i need my car higher anyway..
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
