Which sway bar do I buy first?
Old Dec 23, 2000 | 11:06 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have all the handling upgrades except for sway bars. Which one should I buy first, front or rear? How sells the best, fattest one? How much?
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Old Dec 23, 2000 | 11:13 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You can get the 1LE sway bars, 36mm front 24mm rear from Van Dever's. This is about the cheapest place I have found them. The front sway bar part # is 14094344 and cost $118.88. The rear part # is 10035033 and cost 92.72. The end link kits part # is 10221779 and cost $14.43 a set. The phine number over there is 1-800-362-9494,talk to a guy named Dale and he'll hook ya up.
Old Dec 24, 2000 | 10:04 AM
82camaro's Avatar
Car: 82 camaro SC
Usually, most people say do the front first. This is because an aftermarket bar with a stock rear bar will make your car 'tight' and 'push' when taking a corner really hard(understeer). Doing the rear bar first will make the car 'loose' when taking a corner(oversteer). Understeer is considered safer for unexperienced drivers--most OEM cars push when turning hard. Balance is the key, and I would put both bars on at the same time. I went with the Hellwig brand bars 4 years ago and like them(I can't imagine wanting a stiffer bar. The ride is really harsh, but it handles great. It's 1 5/16 front and I think 1 inch rear. It comes with all the hardware you need(solid end-links) and all poly bushings. The 36mil bar is bigger, but it's hollow. Not to say that's bad, it makes it lighter. It's just not as stiff as a solid 36mil bar, it they made one.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited December 24, 2000).]
Old Dec 24, 2000 | 10:15 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Thanks, The front end tends to break free before the rear but I like that better than the rear breaking free, at least on the street. I have the thickest offered factory bars on my car for a Z28. I want the stiffest ones I can find, I want to pull close to 1.0 g. How much do they cost?
Old Dec 24, 2000 | 11:30 AM
82camaro's Avatar
Car: 82 camaro SC
When I got mine they were about 110 each. Don't forget about you tires, it takes good tires to handle that well. Some other stuff you might consider:
remove excess weight(the stereo stuff), it made a big difference on my car.
LCA relocation bracket with multiple adjustment holes. Drop springs mess up the rear suspension geometry and these correct it.
82camaro
Old Dec 24, 2000 | 12:07 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I will live with the extra weight of the stereo Wow, only $110, cool. What were they called again? Where did you buy them? When I installed the springs I did not notice any other areas starting to lack, even though I know it changes the LCA and panhard geometry. The Panhard is adjustable, BTW. Tires, yes, I am very knowledgeable about tires (I worked at Belle Tire for a year). I currently have 245/50/15 H rated BFG Euro T/A's, basically the best handling tire made for 15's. They work really well for now, but I plan on getting a set of 285/40/17's for the rear and 275's for the front in the future. No money for that purpose right now.
Old Dec 24, 2000 | 02:46 PM
82camaro's Avatar
Car: 82 camaro SC
The LCA relocation brackets will help. But that's a whole other story. Check the "Relocation brackets (lca) are they for traction or more for cornering?
post."
I got them from summit racing(call to get a price)
Hellwig brand http://www.performancesuspension.com/swaybar.htm
82camaro
Old Dec 24, 2000 | 03:25 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Those are for straight line not cornering.
Old Dec 24, 2000 | 03:51 PM
Andy89RS's Avatar
I strongly suggest you do both sway bars at once. If you do only one, no matter which it is, you'll get totally unbalanced handling. Either severe oversteer, or severe understeer. Neither will help your overall performance, and will probably hurt it. If you must do them one at a time, then do the front...
Old Dec 24, 2000 | 10:40 PM
82camaro's Avatar
Car: 82 camaro SC
I completely disagree. The relocation brackets help corning and high speed stability as well as launching.
82camaro
Old Dec 24, 2000 | 10:43 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I doubt it, the panhard bar is the primary support from side to side, those relocation brackets aren't going to help from side to side, not enough to notice at least.
Old Dec 26, 2000 | 10:35 AM
82camaro's Avatar
Car: 82 camaro SC
Not side to side stability, forward bite(traction). The torque applied on the car from the LCA's forces the tires down into the pavement as well as forward with the lowering brackets(the axle mount is lower than the body mount). With a lowered setup, the torque applied on the car from the LCA's forces the tires away from the pavement without the lowering brackets.(the axle mount is higher than the body mount)
Added throttle gives you added traction with the lowering brackets. That helps with cornering.
An example:
The back-end starts to come around in a corner, you get on the throttle and the back-end will bite. Without the brackets and the back-end starts to come around, if you get on the throttle it makes it worse and will spin you out.
It works.
Oh, and I didn't get the brackets to corner--that was just a really nice side effect. I got the brackets to stop my wheel hop problem, which it did.
82camaro
Old Dec 26, 2000 | 10:57 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Now I see what you are saying. Yes, that's sounds right. Do they make a noticeable difference in straight line performance? My car already hooks better than a 4th gen even with the car lowered. Who did you have put them on. How much did they charge you?
Old Dec 29, 2000 | 10:28 AM
82camaro's Avatar
Car: 82 camaro SC
Greatly increase straight line traction, mainly because the wheel hop is gone. I made mine out of some scrap steel and welded them in. Spohn sells them(along with other places), but they have to be welded in.
82camaro
Old Dec 29, 2000 | 01:16 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It's Dal not Dale. Or you can go to www.vandevere.com
James
If the women don't find you handsome they should at least find you handy
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
J-money
Jan 4, 2019 09:45 AM
BumpaD82
Feb 26, 2016 02:57 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
