Drums dragging - repost
Old Dec 30, 2000 | 11:26 AM
JoeIROC's Avatar
I just replaced my drum brake pads today, and had the drums resurfaced. When i was putting the drum back on (over the new brake pads) I noticed it was REALLY difficult to squeak it on over the brakes (driver's side only), yet I managed to do it. When I drive i hear that side dragging, and the parking brake is not really any tighter (i usually notice this when i put on new drum brake pads). Any ideas on why the drum wouldnt fit easily, and what I can do to remedy this problem? Thanks guys...
86 IROC TPI
No mods to date = not enough experience = looking for help
Old Dec 30, 2000 | 12:05 PM
ede's Avatar
ede
did you remove the adjustment made by the self adjuster? return the self adjuster to a shorter position. e brake cable not been tightened? need new springs and related hardwear?
ICON Motorsports
1st & 3rd
Old Dec 30, 2000 | 01:39 PM
JoeIROC's Avatar
I put the self-adjuster all the way to the shortest length, and the springs have still retained their "springiness" as far as i can tell, although they are original. I havent adjusted the brake cable, but its looser than before. I would have expected it to be tight... any suggestions?
86 IROC TPI
Old Dec 31, 2000 | 11:02 AM
JoeIROC's Avatar
ede you were absolutely right! I jacked up the car and checked the drum setup... the star wheel had about 5 turns left in it. After that, the brakes were sweet. However, they seemed a little glazed from the test drive i did, so i filed off the glaze... now they're like brand new.
Thanks for the tip!
86 IROC TPI
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
JSDaddy189
Sep 26, 2015 03:50 PM
Prodigious
Sep 18, 2015 05:23 AM
