weight disc vs drum
Old Dec 31, 2000 | 10:24 PM
Keith5's Avatar
Car: C1500
weight disc vs drum
Which weighs more drum brakes with aluminum drums, or a disc brake setup?
1985 Camaro IROC-Z LB9
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
Old Jan 1, 2001 | 02:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
disc
My Firebird & other stuff
- 4 out of 5 people think the 5th is an idiot
Old Jan 1, 2001 | 08:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think if you had cast drums the disks would still weigh more. The drum system has the drum, backing plate, shoes, wheel cylinder and brake hardware. The heaviest part being the drum. Disk brakes have the rotor, caliper and mount. All three of these parts are heavy. If you had aluminum calipers it would be to close to guess.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited January 01, 2001).]
Old Jan 1, 2001 | 08:39 PM
Keith5's Avatar
Car: C1500
Is a cast drum heavier than a disc? I would think it is, but I've never got to hold an aluminum drum yet. The whole system drum system probably equals or weighs less, but what about the weight that is rotating?
Old Jan 1, 2001 | 10:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It's not the weight of the rotor that's heavy. It's the rotor, caliper and mount that's heavy when compared to the drum. The rest of the drum components (see above) is light. That little 9.5" x 2" drum isn't very heavy.
Rotating mass I would still go with the drum as being lighter. I have both out in my shed but no scale to weigh them. The rotor feels a bit heavier than the drum and it's mass is closer to the center of rotation.
Old Jan 1, 2001 | 11:13 PM
Keith5's Avatar
Car: C1500
Thanks, I think all of my questoins were answered.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
