Anybody using dropped spindles?
Old Sep 10, 2000 | 11:23 PM
John Darragh's Avatar
After recently replacing my struts, I took my car in to have the front end aligned. The guy doing the work was a circle track racer and seemed to know his stuff about chassis and suspension. I asked him about lowering my car. He recommended that I stay away from using springs to lower the car since it can cause problems with the front end binding up. He said it throws the front end geometry all out of whack. I have seen the Beltech 2" dropped spindles and rear lowering springs for the Camaro's, but would like to hear from someone who has used them. Thanks.
1989 IROC Convertible, 305 TPI/Auto, KB super subs, Koni reds, BMR strut tower brace, Accel air filters, MAF screens removed - just the beginning!
Old Sep 11, 2000 | 12:23 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Yes this guy is correct. I dont have the drop spindles yet. I am going to get them with the Baer brake kit all at once. Drop spindles keep the front geometry the same. When you just use springs the geometry changes and you have to get an alignment to correct for it. The main reason people go for the springs is that it is cheaper. Generally all 4 springs cost as much as a set of spindles.
Old Sep 11, 2000 | 03:11 PM
UVA3rdGen's Avatar
My baer spindles rubbed the hell out of my wheel wells when i had my car sitting anything higher then 2.5 inches off the ground. I had to knock them out some to prevent from having to change my tires every 100 miles. Am I the only one who has experianced that? If so it is becuase the wieghtjacks and relocated control arm to fit the eibach racing springs that where on the car when i purchased it.
Old Sep 11, 2000 | 03:28 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Well if you had belltech drop spindles and aftermarket springs then I can see why you would be rubbing. That is like 4" of drop. I think if you put the factory springs in the front it will help with the problem. Unles you dont have the belltech drop spindles. Baer sells modified stock ones and belltechs.
James
Old Sep 11, 2000 | 08:08 PM
WOODY's Avatar
I BOUGHT AND INSTALLED THE BELL TECH PACKAGE (SPINDLES AND REAR SPRINGS) AND DON'T HAVE A PROBLEMS AT ALL. I REUSED MY STOCK FRONT SPRINGS AND THE TOTAL LOWERING WAS ABOUT 2" IN FRONT AND 2" IN THE REAR. ENJOY!
Old Sep 11, 2000 | 10:21 PM
Thanks for the feedback everyone. Looks like I will keep my stock front springs and go with the Bell Tech 2" dropped spindles and rear lowering springs.
Old Dec 29, 2000 | 02:05 AM
chillz's Avatar
me2
Old Dec 29, 2000 | 11:20 AM
nosaint's Avatar
Car: 1986 Trans Am
I have the bell tech kit as well. email me with any questions. I had no probs with the kit but make sure u have a tie rod wrench, when I was done the wheels were facing opposite directions!!!
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
www.members.home.net/nosaint/
Old Dec 29, 2000 | 06:59 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I bought dropped spindles for my Elcamino, and they are alot better than just lowering with springs. Not only is the geometry still the same, but you also still have full suspension travel, well, as far as your tires will let you go. I want to get them for my T/A, but, I want to upgrade the front brakes to bigger ones. What kind of upgrades can you do with the dropped spindles?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Jan 1, 2001 | 08:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I used the Bell Spindles, and the Art Morrison Coil Over Conversion Kit. Redrilled the upper mounts to get the caster right, made for a nice setup. The coilovers allowed an adjustable ride height. Was able to dial in the height so that the inner pivor was an inch higher then the ball joint, so the camber curve was about right, then the big front bar.
Old Jan 11, 2001 | 08:17 AM
Nitro Don's Avatar
Im using BellTech 2" droped spindles with Jamex 1.5" lowering springs.I had to modify the hell out of the front fenderwells.Removed alot of metal.
The front tires now sit up in the fender.It is ultra low!!
If you drive your car alot,I would not reccomend my setup.
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
