Tire / wheel size Q's
Old Jan 18, 2001 | 08:51 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I have a 92 Z28 convertable.
I just purchased some ZR1 camaro ss wheels 17 by 9.
Will 315/35/17's fit on the rear and 275/40/17 on front.
What about 285/40/17 all corners.
Thanks for the help
Louis
Louis
Convertable
92 Z28 305tpi Auto w/Paxton, Ram air mod,Water methanol inj.,52mm T/B,ASM Large tube runners, ported upper & lower intakes,AFPR,23# injectors,1.6 roller rockers,slp tri-y headers,3in. cat,3in. gale banks cat back system,3.42 gears,and much more.
Old Jan 18, 2001 | 10:20 AM
JeffT's Avatar
Car: 1991 Z28
First of all, the ZR1 vette wheels and the Camaro SS wheels are different. The vette wheels are 17x9.5(fr) and 17x11(r) while the SS wheels are 17x9 all around.
No, you don't want to run a 315/35/17 on a 17x9 because it is too wide for the wheel.
The 275/40/17 is ideal for the 17x9 all the way around, however, the 285/40/17 will work but imho looks too fat for the wheel. Also, I believe that you will need spacers for these wheels to fit. You should be able to get the spacers from Andris Skulte(sp?) or Vette Brakes.
Old Jan 18, 2001 | 01:11 PM
Jeft,
Your correct I have the camaro ss wheels
17 x 9.
If I used the 17 x 11 would the 315x35x17 fit in the well on the rear.
Trying to resolve traction problem.
Also has anybody put 17x9 with 285x40x17 on a 3rd gen.
Thank for the Info
Louis
Louis
Convertable
http://www.lbsz28blown.cz28.com
Old Jan 18, 2001 | 02:10 PM
JeffT's Avatar
Car: 1991 Z28
Yes, the 17x11 with 315/35/17 will fit in the well. There should be some guys around here that have pics of this setup. Good luck.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
toronto formula
Nov 10, 2015 06:17 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
