Trying to get rid of ugly PS bracket 83Z...
Car: 83Z28 HO
Transmission: G Force 5 speed
Any of you with a 82-86 F body get rid of your AC compressor and end up having to reuse the ugly stock bracket because you discovered it also supports your Power Steering pump?
I'm talking about the ugly one the bolts onto the driver's side header. I ended up having to use spacers and all kinds of rigged up crap after I got rid of my AC compressor so my PS pump would be in alignment.
Is there a remedy for this like some type of aftermarket bracket? I've tried two so far and neither worked. I discovered the reason they didn't work is because these F bods have a weird "P" series metric power steering pump on them, and most afermarket brackets don't line up properly. Is there one that works out there??
PS - I ordered one I "think" might work - it's a March PS bracket for 78+ SBC part # 20165.....and it's a major rip off....Will it work??
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Trying to get rid of ugly PS bracket 83Z...
I got a zoops kit from summit, works great, just a pain to get it aligned properly.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I just installed the March 20165 and it works great - takes some tweaking with washers, but worked well. BTW I'm no longer TBI or serp setup, I swapped my alt to pass side like your car, and I have no A/C - so it should work well for you. I know it's expensive, but I wasted $40 on an ebay look-a-like and it didn't work at all, so the March $$ is well spent.
Car: 83Z28 HO
They didn't mention that those brackets only fit PS pumps with a keyed pulley pre-'79. I'll let everyone know what those brackets fit when I resell them....at a loss of course..
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
I had no issue with the ebay $40 kits. Tho, I had to grind down a lil bit of the PS pump to get it to fit right, after than, no issue.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Why not just pull the bracket off a V-belt system that wasnt setup for AC and use that?
Car: 83Z28 HO
Car: 83 Camaro
Really man? Cause you can't even see the small *** part where I ground it down cause the bracket over lies it. About it NOT fitting the water pump, someone needs to tell my Z to start spitting belts cause I've had it on there for over a year and no issues. LOL
