advice on lowering 86 iroc with 20's
Old May 3, 2010 | 09:45 PM
camaro_mann's Avatar
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
i have a 86 iroc with 20 in. irocs on it all the way around...front has 245/35 and in the back it had 275/30, and i want to lower it...i think right now all i can afford would be lowering springs.....i sorta like the front a little lower than the back, just a tad, not too much....right now my car sits with the front higher than the back...i want it lowered but not where im going to have rubbing issues...would really appreciate advice and pictures if you guys would, thanks
this is it right here idk why i cant attach the picture
http://viewmorepics.myspace.com/inde...ageID=61318836
Old May 4, 2010 | 08:41 PM
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
Re: advice on lowering 86 iroc with 20's
ttt come on guys can i get some input.....
Old May 4, 2010 | 08:52 PM
Stephen's Avatar
Car: 87 GTA
The easiest way to save money, would be to cut your stock springs. Just don't know how you could go on 20"s, & not start rubbing.
Old May 4, 2010 | 08:54 PM
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
i will pay for lowering springs but idk how to determine how low to go....
Old May 4, 2010 | 09:00 PM
Stephen's Avatar
Car: 87 GTA
Spend more $ for Ground Control Weight Jacks & you can adjust them up of down until you are happy & nothing rubs (or minimal rubbing).
Old May 4, 2010 | 09:04 PM
Car: 1986 Iroc-Z28
Transmission: 4L60
Axle/Gears: 373
that sounds good....summit?
Old May 4, 2010 | 09:09 PM
Stephen's Avatar
Car: 87 GTA
Nope. Order them from Ground Control.
TGO thread about them.....
https://www.thirdgen.org/forums/susp...ml#post4511787
Go here..... Ground Control site and enter the search term CAMARO & you'll find them.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
