how to set up suspension
Old May 6, 2010 | 11:06 PM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
i am looking for some help on how to set up my suspension in my 84 camaro, it has an after market adjustable torque arm, adjustable pan hard bar, and non adjustable after market trailing arm, new stock coil springs, and new stock shocks, but when i lunch my car off the line with my stall converter at 3000 it does this
i have not played with the adjustments at all not to sure what to do to make it better and now that i have upgraded to a 414 from a 30 over 350 i wont it to take off strait down the track. the passanger side tire some times hits the fender. any help is welcome. thanks jason
Old May 6, 2010 | 11:18 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: how to set up suspension
i can't exactly tell what it's doing in the picture. is it just torquing the chassis or is there some tire shake?
Old May 7, 2010 | 10:19 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
kind of looks to me like its laying over on the rr so hard that its steering the car with the rear end. my two suggestions would be stiffer rr spring and lca relocation brackets. but, a little more info on the car would help...how much hp/tq? or atleast what kind of times does it run? and 60' times might be helpful, too.
Old May 7, 2010 | 07:14 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
the easy thing to do would be add a air bag to the RR spring.
when you say " the passanger side tire some times hits the fender"
your talking the RR tire Right?
then yesssss add a air bag.. or get the spring set with the air bag.
saw one just sold on ebay for $60 with springs..
Old May 7, 2010 | 08:09 PM
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
when the pic was taken, it had a 30 over 350, 268 cam, air gap intake, 600 holly carb b&m 3000 stall converter, and stock 350 tranny with 26x10.5 slicks 3:27 gears. it ran a 9.447 at 73.64 in the 1/8, 60 ft was 2.134. but now it has a 414 stroker, aluminum head victor sr intake, 750 holley double pumper, rebuilt 350 tranny stage 2 shift kit, 3:70 gears have not had it to the strip yet to see what she will do.
Old May 7, 2010 | 08:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a big rear sway bar, or a drag bar/antiroll bar would help if its primarily a drag car.
Old May 7, 2010 | 10:35 PM
Car: 91 Camaro
wow, I'm surprised it did that running those times. my best 1/8 mile with my v6 is a 9.51 @ 74 and I've pulled a 2.04 60' on street tires with bone stock suspension (only boxed lcas) and it always went straight as an arrow.
Old May 7, 2010 | 10:39 PM
could be from a list of things from mushy rubber parts to who knows.
but it can be fixed
Old May 8, 2010 | 12:26 AM
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
all bushings are new energy bushings, new shocks, springs, the car dead hooks no spining at all, one had the rim spon in tire moved about 3". the track isn't that good either the races are held at an airport they spray some tration compound down and drag some rubber, my car is one of few that can hook up good, every one else spins till the 60 ft or more. what do they make that i could buy to stiffen the rear springs, is there an acutual kit for the camaro. thanks jason
Old May 8, 2010 | 08:19 AM
Car: 91 Camaro
doesn't moog make a HD or cargo spring that's a high spring rate? or, as mentioned above, get a air bag that goes inside the rr spring. a larger rear sway bar may help but i think i'd try the spring/bag route, first.
Old Aug 21, 2010 | 07:17 PM
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
So I finally got out to race new motor on July 15. I added a set of air bags and it helped a lot, right rear doesn’t squat as much now, best time of day was 7.632, 93.36 mph, 1.817 60 ft, in the 1/8. Made it in to the quick 16 out of 65 cars, but lost out first round.
Got out again Aug 15. Changed out gears to 3:70, changed to a 29x11x15 slick, and ran 110 race fuel. But was cold out in the morning, couldn't hook at all, ran 8.758, 7.908, and 8.299. Again made it to the quick 16, but did get it run because power wire came off distributor during burn out. in the after noon ran a few grudge matches and ran best time yet, 7.508, 94.14 mph, 1.803 60 ft.
Car still has more in it if I could get better traction, spins ¼ track or more.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
