things about suspensions I don't understand:
Old Jan 28, 2001 | 11:52 PM
matthew's Avatar
Panhard rod: what is it? what does it do?
Torque arm: same questions
Torsion bars: ditto
any help on the above terms would really help my understanding
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Jan 29, 2001 | 03:34 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
We have the first two, but not the torsion bars. They were on the older dodges, and the mid '80s nissans and toyotas.
The panhard rod is the bar that is parallel and mounted behind the rear end. It keeps the rear square.
The torque arm is the long rod that mounts your transmission to your rear end. It keeps your rear end from flipping around when you take off.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 29, 2001 | 05:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
To add a visual to what stinger says,,,
Track bar is just another name for a panhard rod.
My Firebird
Part Diagrams
[This message has been edited by deadbird (edited January 29, 2001).]
Old Jan 29, 2001 | 07:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe GM also likes to refer to the sway bars as "stabilizer bars" too.
Old Jan 29, 2001 | 07:28 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
GM still uses Torsion bars on all of there 4X4's. Think of it as a "sway bar" mounted from front to rear with the front end mounted to the lower control arm, and the back end bolted to the frame. It takes the place of the front coil springs, since an axle prevents a coil spring from being there.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
E Rod
Aug 28, 2015 05:17 AM
Bob88GTA
Aug 18, 2015 03:31 PM
