will 4th gen struts and shocks fit a 3rd gen?
Old Jan 28, 2001 | 01:35 AM
Novaguy76's Avatar
I can get a set of 4th gen shocks and struts from a friend that have about 20 miles on them (bought the car new and is replacing all the suspention with after market stuff). I need to know if they will fit my 82 Z28 because the ones on the car are shot.
82 Z28 with 350.motor has .030 forged flat top pistions other wise stock bottom end, Summit 214/224 cam with 1.6 Harland Sharp roller rockers, stock 882 heads for now (will be getting a set of the 23 degree Trick Flows this summer), Performer RPM intake, Holley 750 Vacuum secondary, Th350 with 2200 converter, stock 3.23 geared rearend for now (getting 9" later on), Headman shorty headers, custom 2.5" into 3.5" Y pipe into M.A.C. offroad pipe and M.A.C. cat back system. So far car has only been to the track twice and is having sever traction problems but is running 60'-2.34 1/8 mile-9.2 @ 79 MPH.
Old Jan 28, 2001 | 09:57 AM
Nor Cal Mike's Avatar
Rear Shocks maybe, front shocks I doubt. I'm not very familiar with 4th gens. I would look them over pretty closely, measure the dimensions and compare. I remember an article in one of the mags about changing struts on a 4th gen and it looked alot different. Think about it, if everyone could run 4th gen struts on their 3rd gens, then they could also run 4th gen spindles and brakes. If that could be done, this board would be ringing off the phone lines about it and it isn't.
Mike
Old Jan 28, 2001 | 01:22 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
REAR: yes, they are the same
FRONT: NO! they are very different.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
Old Jan 28, 2001 | 02:53 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Hunter is correct.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jan 28, 2001 | 05:38 PM
Novaguy76's Avatar
ok Thanks... that helps alot.
Old Jan 30, 2001 | 09:17 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
4th gens don't even have a MacPherson Strut suspension w/recirculating ball steering in the front, they have a more traditional short/long arm suspension, with shocks and power rack & pinion. Almost nothing in the front will interchange (sway bar bushings, maybe).
The rear suspensions of the third and fourth gens are almost identical. The only difference I'm aware of is the fourth gen rear is wider.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
