Bump steer kit sleeve size?
Old May 10, 2010 | 07:31 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I am piecing together a bump steer kit, instead of buying the over priced one from Spohn. What I am running into is what size do the sleeves need to be? I see way too many options.
I see this.
http://www.speedwaymotors.com/Alumin...Inch,2087.html
and this.
http://www.speedwaymotors.com/Garage...eve,35240.html
and each one of them has multiple options. Thanks.
Old May 10, 2010 | 08:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Bump steer kit sleeve size?
i have the notes somewhere from mine, i think its 9", but 8.5 would be better. i can check tommorow
Old May 11, 2010 | 07:53 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
What exactly dose this kit help with? Jerky steering while cornering on uneven roads? will you be posting your notes on making this kit with part #'s?
Old May 11, 2010 | 08:46 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
So you have seen the parts for the sleeves. Hopefully //<86TA>\\ can chime in with the length. Here are the rest.
2 Adjustable Tie-Rod End #91636055 Link.
4 spacers #94004016 Link.
4 jam nuts #1756046 Link. You will need 2 packages one LH and one RH.
5/8" shaft and hole
2 RH Heim joints #1750116 Link.
Optional
Heim joint seals #91001504 Link.
Ends up cheaper than Spohn, by a little bit, with upgraded parts. This kit is extremely helpful with lowered cars.
Old May 11, 2010 | 09:53 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you've got one LH and one RH heim joint...how are you planning that? are you using stock inner tie rod ends? if so, wouldn't you need two, either, LH or RH? if you're not using stock inners, wouldn't you need two of each?
Old May 12, 2010 | 10:17 AM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
I would not ever use a non-teflon lined rod end unless you enjoy the sound of the them clunking around. In the steering system that couple thousandths of slop could start adding up to be dangerous as well.
Old May 12, 2010 | 12:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
crap, forgot about this, i'll grab the measurement in a bit
Old May 12, 2010 | 12:34 PM
Twin_Turbo's Avatar
Just use those seals it seals, not cheap but they do work.
Old May 12, 2010 | 01:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the tubes are 9", 9.5 would also work. you dont need a left and a right rod end, just 2 5/8 RH ones, then 2 RH nuts and 2 LH nuts.
Whatever threaded tube you use has to be hollow, and threaded about 2-3" inside so it fits on the inner tie rod, the solid hex bars with 1.5" of threads will nto work, i used heavy sweged tubes.
put the set together for 75 bux, but didnt use top quality rod ends. However, they dont make noise and are still moving after about a year.
Old May 12, 2010 | 01:33 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Yes I will be running stock inner tie rod ends. You are right on the heim joints. I will look for some different heim joints and adjust the list accordingly.
Thanks for the help with this. Are you saying the first link listed will not work (Link.)? Do you have a link to something that will? I looked through the site and found another one, but it doesn't list the thread length. Link.
Old Jan 26, 2012 | 01:55 AM
87350IROC's Avatar
Car: 87' IROC
Back from the dead.
I'm piecing together a bump steer kit of my own. Seems like most of the kits out there put the rod end over the threads of the stud. Seems like putting the rod end over a shoulder would be better. Of course that would mean running spacers then instead of jam nuts.
Thoughts?
Old Jan 26, 2012 | 05:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
with everything tight, there is no play in the connection. the studs are typically fine thread, which is a tighter fit than with course threads.
if you want to use spacers and a 5/8 bolt, thats fine too, but you will have to drill out the spindles.
Old Jan 26, 2012 | 06:02 PM
Roostmeyer's Avatar
Axle/Gears: 3.70
Something else you'll want to do is run a safety washer under the rod end.
https://www.pegasusautoracing.com/pr...p?Product=3068
Its possible for the race to get pounded out of the rod end, dropping the ball. The results could be catastrophic so they're cheap insurance. You should be able to grind a side off the washer if you need more wheel clearance.
Old Jan 26, 2012 | 10:34 PM
87350IROC's Avatar
Car: 87' IROC
That is true, however I would still be more comfortable with a shouldered bolt in the case of relaxed clamp up.
Also, I believe pitstopusa carriers a tapered bolt with shoulder for use with spacers. No drilling required.
At the end of the day, I think I will just use the threaded bolt with deformed nuts.
Ghettobird52
Apr 21, 2020 08:44 PM
toronto formula
Nov 10, 2015 06:17 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
knight72
Aug 10, 2015 09:32 PM
