traction is bad!!!!
Old Jan 31, 2001 | 04:01 AM
bman's Avatar
traction is bad!!!!
with all the drag radials on the market to choose from which one hooks up the best. has to fit on a 16 inch rim
Old Jan 31, 2001 | 08:43 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Mickey Thompson has 2 ET Street tires that'll fit on normal-width 16" rims: 26 x 10.50-16 and 26 x 11.50-16. They have just about the best reputation for hooking up at the track, although they aren't very streetable and might require tubes. Nitto and BF Goodrich both have drag radials, 245/50 for the Nittos and 255/50 for the Comp T/A Drag Radials. The Tire Rack sells the Drag Radials and maybe the Nittos too.
Greg Westphal
'87 IROC 305TPI/A4
Old Jan 31, 2001 | 02:02 PM
bman's Avatar
will the MT 26 x 11.50-16 fit under the fender of an 84 Z28.
thanks
Old Jan 31, 2001 | 10:24 PM
3rdGem's Avatar
I recently bought a rear set of rims that had M&H Racemasters 305-50/16 DOT Drag tires. They are bias ply, and after having them on the car for a few days (in the cold) they ride like crap till they warm up (rolling). Once warm, they hook up VERY well. I read another post earlier; apparently they are hard to come by. When these wear out, I'll probably switch to Nitto's. I've heard a lot of good about them. On my 16X8 rims, they're "slightly" bulged, but fit fine inside the wheelwell. It might just be my WS6 suspension's firmness keeping them from rubbing?? They're about 1/2" (mounted) taller than my 245ZR50/16's I usually run. Hope this helps.
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Soon to be: '73 Daytona (?) Yellow Firebird 350
Check out the newest f-body site: http://www.lastgen.com/
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
gta892000
Sep 16, 2015 12:40 AM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
