P/S Bypass........
Old Jan 31, 2001 | 10:14 PM
CrazyRob75's Avatar
P/S Bypass........
hi guys. I finally got my 454 in and running.My ques. is, I still need to hook up my power steering until I can find an S10 manual gearbox. I started to wonder if I could just pull the pump out and put a fitting in the pressure line of the steering box and just plug the return line. I took it for a quick boot today and it actually isn't that stiff. I know the gear ratio doesn;t have as much assist as a manual box, but I can live with it. I know it's doable, but I just want to know if this would cause any major damage to the box.
Thanks alot.
85 Berlinetta Iroc exterior Lg4 305 best e.t 14.4 street tires naturally aspirated....installing/ rebuilding 450-475 HP 454....YAHOOO!!!
Old Jan 31, 2001 | 10:51 PM
Bort62's Avatar
WEll Ive been Driving Mine with the Pump out for 3 months Now...
One of those things I never seem to have Time to fix
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 1, 2001 | 06:14 PM
CrazyRob75's Avatar
I presume your not having any problems? (except the screwed up pump)
Old Feb 1, 2001 | 08:49 PM
merf23's Avatar
Leave some fluid in the box. Leave the lines in the box vented. A coupla hoses hooked to a small breather might do the trick and look OK too.
Old Feb 1, 2001 | 11:05 PM
CrazyRob75's Avatar
thanks.........that's what I figured. Leave a little oil in there for lube and then go drive the crap out of it!
Old Feb 2, 2001 | 12:10 AM
3rdGem's Avatar
Think of it as an "expanded workout"....imagine the size of your forearms in a couple of weeks
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Soon to be: '73 Daytona (?) Yellow Firebird 350
Check out the newest f-body site: http://www.lastgen.com/
Old Feb 2, 2001 | 12:49 AM
CrazyRob75's Avatar
you must have read my mind!!! I was thinking I needed to start working out Iguess it all started with carrying the BBC cast iron heads around......I feel more macho everyday! LOL
mcquigg
Aug 13, 2015 02:26 PM
RBob
Sep 7, 2004 08:53 PM
JoshDT91
Mar 6, 2004 11:51 AM
pOOn
Jan 28, 2004 11:41 AM
