HELP! Rear Brake Calipers
I just bought my 1990 Formula 350, and i need to do rear brakes on it. i know the rear calipers have a screw-in piston for the E-Brake to work. How do i push this kind of piston back into its bore? As far as I know, you can't just use a C-Clamp and push it in. Any help would be appreciated ASAP!
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You should have the aluminum rear calipers if the car is a 90. In 89 they got the 11.65" rotors and PBR aluminum calipers. So either you have the new ones and you should be able to push the caliper in a bit, or you dont really have a 90, or someone swapped the rears and or brake setup. Sorry though I dont know how to help you.
James
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
James
One my moms caprice, I had to buy a tool that goes on the end of a ratchet. Its a box with tabs on all 6 sides. Each side is for a diffrent application. I just had to push and turn. Hope this helps.
I didn't need that tool, but I have heard that some cars need it, I don't know what years or anything. But anyway, if you don't need that tool it is really easy to do the rear brakes.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
90 IROC 5.7l (L98)
LIKE A ROC
Hey, 90Form350, unless your calipers are in really bad shape, you should be able to use the C-clamp. I know I can, as long as I'm
"gentle"...(leave the monkey in the tool box for another project ). Just take care in the process. Clamp down SLOWLY, and work the piston back into the caliper!
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Soon to be: '73 Daytona (?) Yellow Firebird 350
Check out the newest f-body site: http://www.lastgen.com/
'88 Formula 350
Car: 1986 Firebird
Engine: 2.8 V6
Well, he has different calipers, 3rdGem. But yeah, my Haynes book shows a c-clamp being used for the 82-88 rear pistons. They stress that the clamp should go to the "side" of the center bolt of the piston, not on top of it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Eric-86sc
04-03-2016 03:52 PM
sailtexas186548
01-19-2016 12:21 PM
