Scraping front ground effects
Old Feb 10, 2001 | 12:47 AM
Casey'91Z28's Avatar
Is there anything I can do so I don't scrape the front of my car all the time? I know to angle it out of driveways but sometimes they are just too steep. I'm going to be replacing the front ground effects and painting them and I don't want to scrape them once there all painted. Is there any suspension mod that would help this?
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, 14.7@ 93 mph.
Old Feb 10, 2001 | 02:23 AM
evilho7810's Avatar
Get a bra.
Old Feb 10, 2001 | 11:51 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I have the same problem i bought a new one got it painted and that night i scraped it pissed me off and now its starting to tear again. I remeber someone had a pic on how they costomised it so it wouldnt scrape
Old Feb 10, 2001 | 03:14 PM
85TA-AZ's Avatar
I had the same problem with my T/A and i figured out that it was the front struts that were the problem. I replaced my factory struts which were bad with kyb's and the gound fx stood higher off the ground and didn't scrape anymore.
You should consider changing the front struts if there factory or you think they're bad.
85 Trans AM
305 5sp
180,000 miles
KYB sturts front shocks rear
polyurathane bushings
solid panhard bar
new world class t-5
new clutch
Old Feb 11, 2001 | 12:25 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Is the part that's being scraped really visible or do you have to get down on the ground to see it? If you aren't worried about how the gfx looks and just want it to stop cracking and stuff you might be able to use something like spray on bedliner to strengthen it. It's just a thought. Personally, I wouldn't do it
Frozer!!!
Jan 19, 2024 04:55 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
