why?
Old May 18, 2010 | 04:11 PM
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
why?
ok so today i was out cruisin in my iroc my little brother called me said his car was hesitating so i sea foamed it for him and i took it for a little joyride .... my car is a 1985 iroc/z converted to a 355 carb with the t5 his is a 1985 z/28 with the stock 305 tpi with the 700r4 ... i was just wondering what would make his car ride so smooth in comparison to mine as far as i can tell they both have the same stock suspension or could i be that possibly my 18 inch wheels make my car ride so rough he has stock z/28 wheels... j/w any input? or any tips to make mine ride smoother without sacrificing any handling? heres our cars
MINE
MY BROTHERS
Old May 18, 2010 | 04:27 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: why?
Well for one thing you have o ring tires there's no give or flex on those side walls.
Old May 18, 2010 | 04:32 PM
91rss's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: 10 bolt 3.23
Re: why?
Yes, lower profile tires will make for a little more rough ride, and you could replace all the bushings with rubber polly everywhere will increase stiffness and bind, other than that the spring rates also will make a difference. New struts/shocks would help depending on if you get performance ones, or plain jane softer ones for a stiffer or softer ride.
Stickies at the top have info on shock/strut combo's, and affects of rubber/poly bushings and rod ends.
Old May 18, 2010 | 04:35 PM
zachkuby87's Avatar
Car: 1985 iroc z
Transmission: t-5
Re: why?
any specific parts you guys would recommend??
Old May 18, 2010 | 04:56 PM
Car: 92 camaro B4C
Transmission: t5
Re: why?
Switch rims and tires with your brothers and take it for a ride see how it rids and then try to convince your brother to give you back your old rims a tires.
Old May 18, 2010 | 05:09 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: why?
A quick & easy solution to see if its the tires or not.
Old May 18, 2010 | 07:10 PM
zachkuby87's Avatar
Car: 1985 iroc z
Transmission: t-5
Re: why?
yeah i dont think id be able to get my rims back i owe him 450 bucks right now....
Old May 18, 2010 | 09:32 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: why?
Money Pit has the Smart answer. There are sooooo many variables, so he's spot on. Who knows; he could be riding around with only 15-17 psi air pressure in his tyres.... Nitro
