Power steering info. needed
Old Feb 9, 2001 | 06:55 PM
Hulk0202's Avatar
Im losing power steering fluid somewhere. I think its somewhere on the line coming from the gear box. Im looking in my Chilton, and I can't find the piece. It's like a metal junction with rubber hoses leading off, and some type of sensor. I think its leaking where the rubber comes of the metal. How can I fix this. I tried sealing it with silicon, but no luck. Is this piece expensive. I appreciate any help.
Old Feb 9, 2001 | 07:39 PM
OLDYELLR's Avatar
Car: '85 IROC
You need to replace the high pressure hose assembly. It can't be fixed.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Posi, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Feb 9, 2001 | 07:41 PM
Hulk0202's Avatar
Is that expensive?
Old Feb 11, 2001 | 01:29 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
In the $60 to $70 dollar range. Silicone? On a high pressure line!
Old Feb 11, 2001 | 10:00 PM
84IROC's Avatar
Actually, you can repair this hose by removing it from the car and carefully cut away the crimped outer portion of the hose connection being sure not to damage the inner barbed peice of the connector. Now you can just clamp on a new peice of rubber hose with standard hose clamps. I believe one side of this system is fairly high pressure so be sure to make a good connection.
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front ($10 from wrecking yard)/
"wonder Bar" ($5 from wrecking yard)
23mm sta. bar in rear
Rear RS Springs (slightly softer than my Z28)
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
powersteering cooler lines (liberated from another wrecked car of course)
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
home-made strut tower brace (cost $6)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
