e-brake
Old Feb 13, 2001 | 08:52 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
e-brake
my e-brake doesn't work at all does this mean i have to replace the drums or does the cable have to be adjusted?
Old Feb 14, 2001 | 10:10 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There is a star adjuster in the drum brakes. Go through the window slot to adjust it with either a screwdriver or buy the brake adjusting tool at auto parts store. Adjust it until the brakes begin to drag. There was no provision to adjust the e-brake cable itself on my 90 RS. But the older style had a threaded center rod at the saddle that connects to the 2 brake cables. If yours is that style then it can be adjusted there. It is easier if you disconnect the driveshaft from the rear end and let it hang down out of the way.
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
