mini spool?
mini spool?
I heard some guys talking about a putting a mini spool in the rear end to help the car lock up better. But they said be careful in the rain. What exactly is a mini spool and how does it work?
T.J.
91 camaro RS , LO3 not many mods yet but plan to in the future
T.J.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A mini spool replaces the spider gears inside the carrier. It locks the 2 axles together so they will always turn at the same speed. When going around a corner a differential allows the outside wheel to turn faster than the inside one. If the axles are locked, usually the outside wheel will slide across the pavement since it's turning at the same speed as the inside wheel. This is hard on tires and axles.
A mini spool is a cheap counterpart to a full spool. A full spool does the same thing however it replaces the complete carrier making it much stronger. The mini spool can be installed in a few hours in the driveway since it just replaces the spider gears.
There are no full spools available for the 7.5/7.625 10 bolt and unless the manufactures have added new stock, the only mini spools available for the 10 bolt is 26 spline. The main problem being that our small 10 bolt diffs are not considered performance parts and because of this, parts like spools and mini-spools are just not created for them.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
i see that mini spools are pretty cheap compared to new posi,locker,etc units. this may be a cheap alternative to traction. spend the $100 now and save up the the 9".
though used limited slips from 4th gens are plentiful and really cheap.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have real good tires,, a mini spool (or full) is a good way to strip the splines or snap an axle.
My Firebird
Your Car Here?
Part Diagrams
My Firebird
Your Car Here?
Part Diagrams
Its also a good way to end up facing the wrong Direction In the Rain ( or otherwise )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
darwinprice
17
Oct 11, 2015 11:51 PM
