Too High?
Old Feb 24, 2001 | 12:44 PM
Hulk0202's Avatar
Too High?
I just finished rebuilding my front suspension and replacing my struts. Now the car seems to be much higher up front. I figure this is normal considering the old stuff had 142,000 miles on it. Well is it normal?
Old Feb 24, 2001 | 10:04 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
It may be if you replaced your stock springs too. The stock springs usually sag, especially after 100,000 miles roll under the wheels.
Old Feb 25, 2001 | 11:50 AM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I have the same problem. I think its due to the rear springs sagging over time. My rear sits about an inch and a half lower than the front. The only way I can see to fix it would be to replace the springs or lower the front to match, it's up to you. Good luck
Old Feb 25, 2001 | 02:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You probably didn't tighten the control arm bolts with the car at ride height. This will pre-load the bushings incorrectly and contribute to ride height.
Have you driven the car yet? When you raise the car, the wheels tuck in. Then when you let it down, the friction between the tire and the work surface keeps them tucked in. If you roll the car foward, it should settle.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
