Tired of car being unstable What good suspension mods should I look into?
Old Feb 24, 2001 | 02:47 PM
theformula's Avatar
Check my signature for info on my car. It says I have auburn posi. I do, but it's not installed yet. So my rear is OPEN.
The roads here are dry.
I went through a puddle while exiting Red Lobster . I drove down the road a little then gunned it in 2nd gear. My car started going no where while RPMs were rising. Was this because my tires were a little wet? Do I have to much hp for street tires to be doing this? Is it because of the open rear I have?
What can I do to prevent this?? Any suspension mods?
I really do not want to wreck my car again...
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 25, 2001 | 02:59 PM
BTS88IROC's Avatar
Yes, I'm sure you have a little bit too much hp for those street tires, especially when you are only having to spin one! The posi will help out a little. Try some SFC's those will cut down the tire spin. Also some LCA's and a panhard rod. All these combined should considerably cut down on tire spin. What size tire are you running? Stock?
Old Feb 25, 2001 | 03:47 PM
theformula's Avatar
Yea stock 245/50/16s
Old Feb 26, 2001 | 01:06 AM
Bort62's Avatar
Keep your foot out of It ?
Just an idea...
Seriously Tho, What BTS said. Also Look at getting some better tires, depending on what You have now.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
