Swaybar experts
Old Feb 23, 2001 | 11:32 PM
iroc22's Avatar
Swaybar experts
Has anybody every heard of a 1 1/2 inch front sway bar(38mm)? I measured the bar over and over with a measuring caliper and it always comes to 1 1/2 inch. I've even measured different parts of the bar and they're always 1.5 inch (comes out to 38mm!). I know there is going to be somebody out there that insists that my bar is 36mm, but no it's not! I even pulled out the mounts and measured the diameter and it's 1 1/2. The reason this is such a big deal is that I am going to need a need swaybar mount and nothing is that big. Just for reference, my back bar is exactly 1 inch or 25mm. My car is a 1989 IROC Convertible.
Also there was some other guy that had the same problem as me. I think his name was ROCHEAD.
Old Feb 24, 2001 | 12:15 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You prolly got aftermarket bars on it.
Old Feb 24, 2001 | 11:10 AM
82camaro's Avatar
Car: 82 camaro SC
Maybe it's been painted or has a good coat of rust on it. Use some emery cloth or sand paper and sand it to bare metal and re-measure in mm(no conversion). A good spot to measure would be at the bushing(remove the bushing and measure) I don't know of any aftermarket bar that big. What do the end-links look like? What do the bushings look like? Aftermarket bars usually use a solid end-link(nut on top and bottom with no threads showing) with poly bushings, or a solid mount(no bushings). If the endlinks are stock, I'd say it's a stock bar. 36mm hollow.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited February 24, 2001).]
Old Feb 25, 2001 | 05:10 PM
ROCHEAD's Avatar
Hey finally someone with the same bar as me. Actually it measures alittle bit under 11/2 but not by much. Try finding the serial number , its in the middle of the bar, mine reads X189 or XI89. I can't get any response from GM on them either. I can't find anyone with polyurathane bushings that big, so im gonna take the 36mm i have and drill them out. My car is also an 89, but hard top and has the 350.
Old Feb 25, 2001 | 11:18 PM
82camaro's Avatar
Car: 82 camaro SC
36mm is 1.4173228346456692 inches.
82camaro
Old Feb 26, 2001 | 05:41 PM
iroc22's Avatar
I have a serial number on the bar and I think it says X338 or something along those lines.
Old Feb 5, 2005 | 12:05 PM
SilentBob's Avatar
Car: it doesnt really drive right now
Engine: 383
I know this is a long dead topic, but I too have the 38mm bar on my car and performance suspension here in town does not have a bushing big enough. Anyone know where to get one at this point? (Aside from factory).
-SB
Old Feb 5, 2005 | 12:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
For as long as I have been on boards the largest I have ever seen was a 36MM. Only place I know carries those bushings are TDS or Gulf Strand I to thought I had a larger bar under I accually sanded it all down and got the rust and paint off. It was then a true 36 and this came on a 89 Formula 350 Hardtop
Old Feb 5, 2005 | 01:37 PM
SilentBob's Avatar
Engine: 383
Craziness. I'm in AZ, so rust really isnt a problem, and I did measure the bar right at the bushing mount, so I dont think there would be enough paint there to throw off the measurements 2mm, but I suppose anything is possible.
I can use the stock bushings for the time being and sand it down later and see what I can figure out.
The car is an 89 IROC that had the 350.
Old Feb 5, 2005 | 02:26 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
My X189 is a 36 mm hollow bar, it measures 36.01mm and 36.03mm in a different place. If it has a serial number on it, it is not 38mm.
Old Feb 5, 2005 | 02:28 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What kind of caliper are you using, are you using it correctly?
Old Feb 5, 2005 | 09:11 PM
iroc22's Avatar
This thread was dug up from the dead.
That bar turned on my vert turned out to be a 36mm when I replaced the bushings.
Old Feb 6, 2005 | 12:27 AM
SilentBob's Avatar
Engine: 383
Using the caliper that they had at autozone. Pretty sure I was using it correctly, but I have been wrong before. Ill order the 36s and post back the results.
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
