Installed a new front sway bar over the weekend, I'm having an issue with the sway bar hitting the shocks when turning. I thought I had it installed upside down at first so I flipped it around and that made it a little worse if anything! To me it looks like the end links are too long. Will it matter if I make the spacer in the middle of both end links like an inch shorter? My thinking is if I do the same to both sides it shouldn't matter, but I've been wrong before..
whos sway bar? addco?
dont see any problem with shorter links, if both are the same
Spohn.
I got some 1" sleeves and shorter bolts (came with 2" sleeves) and it all seemed to go together fine. Won't really know if there's an issue with it until I get the car back on the road though!
