For performance; to lower or not to lower?
Old Feb 28, 2001 | 05:54 PM
86Trans Am's Avatar
I going to be doing my suspension soon and am still wondering if lowering would be the best thing. I would like a lower stance for the visual aspect or the car but the bottom line in performance. Will lowering the car give me better all around performance, street, strip, and road races?
Jamex
eibach
edelbrock
intrax
I would not want to lower it more than an inch, so from the above brands which one do you suggest would be the best for what i'm looking for if lowering the car is the way to go. I'll probably be running bilstien shocks and struts with poly bushings.
thank you
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Feb 28, 2001 | 06:53 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Lowering the car will actually help the vehicle corner better because of the lower center of gravity.Also,if you get lower springs with stiffer spring rates(which is how most of them will be),the car will not lean as bad during hard cornering. And I believe the Eibach pro-kit series only drop our cars 1"-1 1/2".
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood, High-rise Z-28 spoiler
Flowmaster cat-back
TBI mods
383 soon to come.
Old Mar 1, 2001 | 02:38 PM
86Trans Am's Avatar
1986 Trans Am
305 TPI
Old Mar 1, 2001 | 08:39 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Don't get the intrax then if you only want an inch, they advertise a two inch drop.
Lowering will be great for looks and the twistys but not so good straight line. The rear lower control arm geometery will be altered resulting in increased wheel hop.
Ask me how I know!!!
This can be compensated for by relocating the LCA's with a lowering bracket welded to the rear axle mount.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Mar 3, 2001 | 04:25 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
IVE GOT THE EDELBROCK SPRINGS IN ADN IT LOWERED MY CAR BY ABOUT 1 INCH. i HAVE NOTCIED MUCH BETTER HANDLING AND CORNING ABLITY BUT ON THE NEGITIVE I HAVE NOTICED MORE WHEEL HOP AS WELL. i RECOMMNED ONCE YOU INSTALL THE SRPINGS GET BOXED LCA'S FORM EITHE SLP OR HOTCHIS AND THAT WILL FIX THE WHEEL HOP.
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , SLP boxed LCA's and panhard bar, ascd ram air hood, Z28 spoiler, white guage faces.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
