Moser 9 inch
Old Mar 2, 2001 | 02:14 PM
92formula's Avatar
Car: 1992 formula WS6
Engine: none
Moser 9 inch
Where are I get a moser 9 inch. how much for them and putting a 3.73 gears with 31-spline axles. How much will this cost and where can i get this.
cheers
Old Mar 2, 2001 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Typical 9" setup like that will run you around $2000.
31 spline is cheap and will be all that most cars will need. Gear ratio is whatever you want for the same cost. Prices will vary depending on if you want a posi, locker, spool etc.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 2, 2001 | 09:21 PM
89BlwnRs's Avatar
Check out www.spohn.net. He's got Moser 9" rear for our cars.
Jason
Old Mar 4, 2001 | 06:29 AM
Hi-psi's Avatar
Try Gears R Us. http://www.gearsareus.com/ I just got a Moser 9", 31-spline, 3.25 gears, Detroit Locker, complete for $1600 shipped.
Robert
'89 Turbo Trans Am
#799 of 1555
11.96 @ 109.11 w/1.62 60ft BEST Race Gas
12.53 @ 105.31 w/1.74 60ft.BEST Pump Gas
www.Hi-psi.com
[This message has been edited by Hi-psi (edited March 04, 2001).]
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
