Drum to disc proportioning valve?
Old Feb 28, 2001 | 03:26 PM
kermit_one's Avatar
Here's the question,I put a 4th gen rear with discs in a few months ago,and haven't put a new propotioning valve in yet.I don't want to use an adjustable one.Will a 1LE proportioning valve help me out any.The discs on the rear are huge compared to the front so I will be upgrading to 1LE or Baer in the future,but for now i need better brakes.The front are doing all the work right now and i've been pushing my luck here lately.Thanks for any help guys.
92RS,POLO GREEN
Old Feb 28, 2001 | 10:31 PM
kermit_one's Avatar
ttt
92RS,POLO GREEN
Old Mar 2, 2001 | 03:23 PM
kermit_one's Avatar
ttt....come on guys....anyone? i'll even take a wild guess at this point...lol
92RS,POLO GREEN
Old Mar 2, 2001 | 03:44 PM
Stang Eater's Avatar
you wouldnt even have to get a 1LE prop valve to get it at least close to what it should be, even if you found an iroc or Z28 with 4-wheel disc it would be closer then you are now.
P.S- Im guessing that you had drums before????
Let me know what you find out, i want to put in a 4th gen rear also
Old Mar 2, 2001 | 04:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd venture to say it has to do with how similar the brake systems were between the late 3rd (specifically 89-92) and 4th gen f-bodies. I searched thru carparts.com and they don't list any prop valves for 93-up f-bodies. They listed AC-Delco #172-2074 and AC-Delco #172-2038 for the 92 Z28, the 2074 looks like it's for rear discs.
Luck would be great if the 93-up's use the same prop valve as 89-92! I say give a few GM dealers a call, and ask for part #'s.
If the 93-up rear discs are larger or more powerful than 89-92 rear discs, you should probably hunt down a 4th gen prop valve. If they're the same size/power/etc, the 3rd gen one would probably do fine.
I was told the prop valve doesn't do any proportioning for 4-wheel-discs. It's just a combination valve, to split the m/c outputs into three, and give the BRAKE pressure warning light a home. If that's the case, then any 4-wheel-disc prop valve that fits your lines would work great.
But if the 93-up rear discs are huge, maybe this would screw something up? These are just guesses here, by the way...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited March 02, 2001).]
Old Mar 2, 2001 | 06:21 PM
kermit_one's Avatar
Hey thanks guys,even the guesses help,lol
it did have drums and yes the rotors in the rear are 12"s i believe.The brakes work well enough to slow me down,but the rear aren't doing anything.The only reason i was thinking of the 1LE valve is cause it uses the 12" rotors on 4 corners.I'll look into the 4th gen proportioning valve,i may call thirdgen parts and see what he has available,thanks for the replys........
92RS,POLO GREEN
Old Mar 4, 2001 | 06:25 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
you need GM part # 10136840
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Mar 4, 2001 | 11:10 PM
kermit_one's Avatar
Thanks Andy............
92RS,POLO GREEN
devilschariot
Feb 25, 2016 03:08 AM
355tpipickup
Sep 13, 2015 11:35 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
