Help - Caliper removal
Old Feb 24, 2001 | 12:05 AM
Adam89F's Avatar
Hey guys.
I'm having some difficulty removing the pins on my 89's front caliper. I'm using a hex-head attachment in my socket wrench and turing the wrench clockwise (sitting beside the car)
It is stubburn and stuck. What can I do?
Notes:
  • I do not have any air tools and shocking it with a hammer has has no effect.
  • I only have a small jack so I can't get the car too high off the ground.
Old Feb 24, 2001 | 12:19 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Looking at the bolt, you should be turning it counterclockwise. Try some WD-40 and let it soak. If you cant get it to budge, try using a big breakerbar on it, possibily with a pipe attached to the end. You may have to turn the steering all the way to the side to fit that in though.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Feb 24, 2001 | 04:20 PM
Adam89F's Avatar
Thanks Justins86bird
Okay, these things are stuck.
I just broke my 1/4" socket attempting to remove the same bolt.
I've used a size 10 hex head adapter in a 1/4" socket on my wrench. I thought I heard people say to use a 3/8" hex head but it is too big.
I guess I have no choice but to wait until May and take it into a shop.
Damn
British Columbia Enthusiast
1989 Formula 305 TBI
[This message has been edited by Adam89F (edited February 24, 2001).]
Old Feb 27, 2001 | 11:08 PM
Fastcamaro87's Avatar
use a 3/8 in hex head and a 3/8 in drive ratchet, soak that bad boy with some PB blaster or wd 40, then take a wack at it , if that dont work, heat that ***** with a torch for a few mins, and it should come right out, just dont break the head off it, man does that suck ,and it is no fun to remove after that.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Feb 27, 2001 | 11:16 PM
Danny T's Avatar
Wow never saw one that stuck before
I've always just used a regular hex wrench
usually tapping it with a hammer a bit to
get the bolt broke loose. Make sure you clean the bolts back up before reassembly so that the caliper slides smoothly on it and and doesnt hang up.
Old Feb 28, 2001 | 12:43 AM
Bort62's Avatar
What Brand Ratchet Did You Break ? China Special ?
Use a 3/8 drive Ratchet and Just Do A lat Pull On it.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 28, 2001 | 03:47 AM
Adam89F's Avatar
I used a Mastercraft socket.
The 3/8 hex doesn't fit.
I'll ask the guys around town.
Old Mar 5, 2001 | 06:05 AM
Belker's Avatar
For my car I use a regular 3/8" allen wrench (L-shaped) and use a 8 inch pipe as a cheater bar. If it's really stuck then I've tapped the bar with a hammer. It's always worked for me pretty well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Stroopwafel
Sep 11, 2015 06:38 AM
