10 inch 1LE front brakes?
Old Mar 4, 2001 | 11:51 PM
BenDoe's Avatar
I was looking at my car the other day for a couple hours when i noticed that the front brakes were smaller than the rear brakes. I measured the rear brakes some timea ago and read 11 inches.. but the front one seam to be about an inch smaller? Could a dealer have made the hurendous mistake of replacing the rotors with smaller ones? Would he have had to replace the calipers and other suspension pieces too? How much do new 1LE front rotors and calipers cost? Any help appreciated.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Mar 5, 2001 | 12:05 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Are you sure you have a 1LE car? The front brakes that came on all '91 non-1LE Camaros were 10 inch rotors with single piston cast iron calipers. The 1LE had 12 inch rotors and dual piston aluminum calipers. I really doubt that the dealer replaced the 1LE brakes with the smaller ones. Unless he changed the spindles also, he could never have done this. Check your RPO codes and double check if you have the 1LE code or the J65 (regular front brakes) code.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Mar 5, 2001 | 05:33 PM
BenDoe's Avatar
ya its a 1le. It has the aluminum driveshaft, 11 inch rear drums, and it has the 1LE code in the glove box. It has been hit in the passanger side front front somewhere because it has a frame welding near the passanger foot.
Old Mar 5, 2001 | 10:06 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by BenDoe:
...It has the aluminum driveshaft, 11 inch rear drums, ...</font>
Rear drums?? You mean discs right? AL driveshafts mean nothing, all my GTA's have had them. My '89 (as well as everyone else's) had the same rear discs that year and up. The rears should be close to 11.5" and the fronts 12", both with PBR calipers and the fronts sporting dual pistons. Double check your codes with the sticker in the trunk, or figure out your 5th gear ratio is.
"A lawyer with his briefcase can steal more than a hundred men with guns."
-Mario Puzo
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
