I need 1LE brake answer fast.
Old Mar 19, 2001 | 11:07 PM
BenDoe's Avatar
I have a friend going to a junkyard tomorrow morning, and i need an answer. Could i get the 1LE brakes off of another car. I think i read somewhere that they took the 12 inch rotor and spindles from the cavelier.. is that right. The question is basically, is there another car in a junkyard that i could take the brakes and rotors from, and i so what is it, and what years?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Mar 20, 2001 | 04:24 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Ben, If you will look down this board you will see that much effort has been put into "this 1LE" brake question. As far as finding one in a junk yard. I would say that you have a better chance of riding on the space shuttle. I made my own 1LE spindles. Jay,and I will be posting many picsures of my 1LE front brake upgrade soon. I am installing them on my '82Z28.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Mar 20, 2001 | 05:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 1LE brakes came from Corvettes, and were available on 88-92 1LE Camaros and Firebirds, and also on late 91 and 92 B4C Camaro cop cars. The chances of finding one of these in a junkyard are zero and none. See the tech article on here, it lists everyone you need to convert your brakes.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
IROCZ1989
Sep 4, 2015 11:54 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
