ok gonna do it
Old Mar 21, 2001 | 10:53 PM
PopaPork's Avatar
ok gonna do it
Gonna lower the RS, any one know HOW to do it? Step by Step or best of your knowledge would help
89 Rs Camaro 305 TBI
Costum Performance Chip
Open Air Element
80 Series FlowMaster Muffler 2.5 inch Cat Back
BFG 235/60r15 Apperance: Black gray pinstripe. Black interior with Gray center piece in seat. Blue Gauge lights and 2 Blue neons under dash Board.
90 Iroc Checkerd Tail lights
Iroc Foglights
System: Pioneer 5200 Head unit Polk 3 ways up front and in the back. Kenwood 300 watt amp pumpin a 8inch JBL GT
"So many engines, so little time"
Old Mar 22, 2001 | 12:16 PM
RoadRacin85Z's Avatar
How much are you planning on lowering it? If you're going just for looks, and want the lowest ride possible, then there are Eibach's Sportline springs (1 3/4" to 2" if I remember correctly), and there are also spindles you can buy for the front to lower it 2". For the rear, just springs should get it where you want it. It all depends on how low you want to go.
Before you lower it though, I recommend you take a good look underneath your car. These cars do not have a whole lot of ground clearance, and be prepared to scrape on about everything, especially if your roads are as bad as they are here in NC...
-Joel Likness
- 85 Z28 In Progress
Road Racer
- 85 S10 350/350
Drag Racer
- 85 Nissan 200SX (yes, it's Japanese)
Circle Track Car
- 91 Lumina 3.1 Euro
Daily Driver
Old Mar 22, 2001 | 07:32 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
if you cut the stock springs cut only a half coil at a time. it drops quick.i cut one coil on my car and it made the car too low.the CORRECT way is dropped spindles
92projectcamaro
Dec 8, 2015 12:25 AM
Zane Story
Oct 8, 2015 12:40 PM
91 SrS
Oct 7, 2015 04:32 PM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Vincent135
Sep 28, 2015 10:50 PM
