Any tips for getting the TA bushing off?
Old Mar 19, 2001 | 01:14 PM
Biochem's Avatar
Car: 2002 SOM z28
Well, I finally got around to changing the thrashed tranny mount yesterday. When I had the tranny crossmember off, I thought it would be a good time to change the TA bushing too. However, while I got the nuts off the 3 long bolts, I was not able to slip them out to get the TA bushing/houseing off.
I assume I need to lower the tranny tail until the houseing will slide off, then drill out the rivots and put the new bushing in... right?
I'll watch out for the torque arm too once I get the bushing off too!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Mar 19, 2001 | 01:24 PM
Jza's Avatar
Jza
There's a bolt on the bushing housing itself if I remember right. Little ol' short thing. Undo that, and it should be able to open like a clamshell. Pull down on the torque arm while you're doing that, then let the torque arm over and out of the bushing. The force on it is not such that a 100 lb kid couldn't handle it. Ease it against the top of the tunnel.
Old Mar 19, 2001 | 02:52 PM
Biochem's Avatar
Car: 2002 SOM z28
Yeah, I know exactly which bolt you are talking about. Unfortunately, I have tried 3 times to get that bolt off with no luck while I am under the car. Liquid wrench doesn't touch it! I am hoping it is simply due to a bad angle of attack...
Old Mar 22, 2001 | 02:20 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
i just removed the whole torque arm...
it made getting to the bushing a lot easier...
btw... i havent put it back on yet...
still need to get a new poly bushing...
later,
Chris
Old Mar 23, 2001 | 01:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Biochem, I know that long bolt you're talking about! I was swapping trannies when I did my torque arm bushing, so the tailshaft was lower than the tunnel. In fact, heh, it wasn't until I bolted the crossmember back up, and went to do the torque arm bushing, that I noticed I forgot to put the long bolt in. I had to lower the trans again!
It's not -that- bad...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Thaney9
Oct 15, 2015 06:37 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
