what do u think of my cornering capabilities w/ my suspension mods
Old Mar 21, 2001 | 12:21 PM
vortech305's Avatar
I ordered the set of billenstien shocks and struts, Lakewood contol arms,lakewood panhard bar, Jegster torque arm, Jamex strut tower brace. All parts have poly bushing
Future im getting front and rear swaybar and 275 comp Z tires.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 23, 2001 | 02:09 PM
vortech305's Avatar
ANYONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
92' camaro
Soon to come!!!
Other car;
Old Mar 23, 2001 | 03:04 PM
jayg's Avatar
Car: 1992 Formula 350
The tires are the most important part of the combination as well as your alignment and balancing the components. Bigger and stiffer is not always better(no funny comments,heehee). Poly bushings are OK but for the ultimate in cornering spherical bearings are the way to go. They allow the suspension to perform bind-free Check out our sponsor, Spohn. You may want to go with some LCA relocation brackets as well. Have fun!
Old Mar 23, 2001 | 03:06 PM
Buck Mustard's Avatar
I think your car will have better cornering capabilities than it did in stock form.
Is that what you wanted to know?
Old Mar 23, 2001 | 03:20 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
LOWERING THE CAR WILL HELP GREATLY AS WELL.
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , aftermarket LCA,s and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
Old Mar 23, 2001 | 04:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also think it will be better. But you probably knew that already...
Old Mar 24, 2001 | 12:22 AM
vortech305's Avatar
thanks thats all i wanted to know
Frozer!!!
Jan 19, 2024 04:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
junkyarddog
Jul 25, 2001 11:04 AM
88blkiroc
Jul 20, 2001 10:29 PM
88blkiroc
Jun 25, 2001 10:48 PM
