weld in ssm's just haven't been solid, what other subs will fit along with my ssm's?
Old Mar 21, 2001 | 07:13 PM
iroctpis's Avatar
i've read about people putting 2 sets of subs on their car anyone done this with ssm's? I want it to be solid
89 iroc 5.7 can't go fast enough. 14.1
Old Mar 21, 2001 | 08:16 PM
dnovotny's Avatar
I just put in two sets of SFCs in my '91 GTA. Global West SFCs go along the rocker panel like SSMs except they are tubular and connect to a stronger part of the subframe. The other SFCs are from Alston. The SFCs don't interfere with each other, since they connect to different parts of the cars frame.
Dave '91 T/A, '91 GTA
Old Mar 21, 2001 | 11:27 PM
IrocStan's Avatar
dnovotny,
Can you post some pics of that?
87 IROC 350
13.94@103mph
Check out my new web page.
http://austinsiroc.homestead.com/Home1.html
Old Mar 22, 2001 | 08:48 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
IrocStan,
Just get some strong bungee cords ane connect them to your lca's and up to your front subframe. These helped my car launch a lot harder. Almost like a slingshot effect. J/K.
Anyway we need to talk about my gear 'cause its getting scary noisy.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 22, 2001 | 02:35 PM
dnovotny's Avatar
IrocStan,
I will take some photos on Monday. The shop did a really good job, but didn't weld the GW connectors to the rocker panel that runs along the connectors. While they're doing that, I'll take the photos.
Old Mar 25, 2001 | 09:30 PM
jayg's Avatar
Car: 1992 Formula 350
Hey, I did the same thing with the Alstons and Global West SFC's. Here is a pic.
http://www.geocities.com/rgades/SFC.html?985577332600
Old Mar 26, 2001 | 12:06 AM
RARE-ROC-Z's Avatar
hey do the alstons cut down on your ground clearance?
which companies do you suggest in buying? thanks
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
BADNBLK
Nov 16, 2016 09:12 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
