SS Camaro wheels don't fit '95 rear!
Old Mar 25, 2001 | 03:14 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I have a set of 1997-8 Camaro SS (ZR-1 style)wheels and tires I'm installing now. I pulled the rear out of my '86 and sold it, and replaced it with a disc-brake 1995 Camaro Z28 rearend, so I can use the wheels. The problem is the wheels don't fit the hub snout. The bolt pattern and all is the same, but the wheel will center, but not seat on the hub. There is a 1/2" gap between the contact surface of the wheel and hub. I took out the centercaps and saw there is a small lip on the inside of the wheel going inwards...where the snout fits...do these need to be filed smaller? I have the right hardware...what's going on? Anybody have this problem?
Old Mar 25, 2001 | 08:49 PM
Jza's Avatar
Jza
They may be centering rings press fit into the wheel. You might be able to pop them out with a screwdriver or something, but first make sure that's actually the case.
Old Mar 25, 2001 | 11:26 PM
vortech305's Avatar
hey dhiroc-z if u ever consider about selling the ZR1 rims let me know and make an offer. Unless of course your not interested
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 27, 2001 | 06:44 PM
Tas's Avatar
Tas
just file down the center of the rim a bit with a grinder. I think its the one thats like a flapping wheel. it has sand paper flaps on it. Am I making any sense? anyone know about the grinding/sanding attachment I'm talking about?
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Old Mar 27, 2001 | 06:48 PM
dhirocz's Avatar
Yeah, I know. They use those in porting kits. Not a bad idea. It's just a tiny bit off, so it shouldnt take long. I'll give it a shot. Thanks!
Old Mar 27, 2001 | 08:26 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
use a brake or cylinder hone
Old Mar 28, 2001 | 02:52 PM
Pino91Formula's Avatar
I had the same problem on my buddies 95 Z28 ,, new ZR1 wheels ,, we just grinded down the lip on the back of the wheel hub
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
kah992
Aug 19, 2015 02:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
