did i do this right?
Old Jun 23, 2010 | 09:26 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I finally got around to start rebuilding the front end in my 91 Trans Am WS6. Today I was putting in the new steering links, and something doesn't feel totally right with my center link. I was able to bolt down the "stud" holding one side to the idler arm quite a bit more than the side attached to the pitman arm. Here's a couple pictures:
You can see how the gasket/washer is squished a bit more on the idler arm side:
pitman arm:
Is that something I would want to address? I was able to torque down the idler arm bolt pretty significantly compared to the pitman arm. I torqued the pitman arm one as hard as I could and that's the best I got. The center link and idler arm are brand new Moog parts; the pitman arm is still original.
Old Jun 23, 2010 | 10:03 PM
lonesomeloser's Avatar
Car: 1983 Z28
Re: did i do this right?
You will have to turn the wheel to be able to get a socket on the pitman arm side. I just did mine today, between 35-40 ft/lbs.
Old Jun 23, 2010 | 10:23 PM
Engine: LB9
Thanks but yeah I know, I already did that. It's still just like in the pictures.
Old Jun 24, 2010 | 10:44 AM
Engine: LB9
bump.... I'm sure somebody knows!
Old Jun 24, 2010 | 11:12 AM
87350IROC's Avatar
Car: 87' IROC
I just put on my Spohn front end rebuild kit and it is the same way. I don't think its a problem if the stud is seated in the hole.
Old Jun 24, 2010 | 11:13 AM
Car: 1983 Z28
If it's torqued properly as you say, and it is parallel with the idler arm, then it's fine.
Old Jun 24, 2010 | 12:11 PM
Engine: LB9
Ok sounds good... thanks guys!
