weld in subframe connector
Old Jun 23, 2010 | 07:54 AM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
hey everyone, i just bought a 82 z28 camaro that has a 383 stroked motor and 700r4 t-tops, and i looking for a good set of weld in subframe connectors, what kind of weld on connectors are out there or what u guys running.
thanks.
Old Jun 23, 2010 | 08:52 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Re: weld in subframe connector
Go with the UMI performance subframe connectors. Good stuff they make.
Tony.
Old Jun 23, 2010 | 09:02 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I've put inner and outer subframes on my car.... Had a good experience with them.. Can jack the car with them as well. It's your choice, but I would recommend getting the inner AND outer with that much power, especially since you have a t-top car (like mine). I found having both made it stiffer.
Old Jun 23, 2010 | 09:35 AM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
yea i wanna make the car as stiff as possible i was also looking into a 8 point roll cage but i wanna kind use the back seats since i have a 3 years old son.
Old Jun 23, 2010 | 09:53 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I got pics someplace of my UMI's
http://s415.photobucket.com/albums/p...C-Z/?start=320
Go back a few pages or forward the're in there someplace lol
Old Jun 23, 2010 | 10:12 AM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
89iroc- u have a pretty sweet car there. thanks for the pics. how is the exhaust on the pass side with the subframe connectors?
Old Jun 23, 2010 | 10:23 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Thanks! The hooker Y is about .5" away from the sfc, plenty of room and there isn't any discoloration on the powdercoat. A stock Y will have even more room, but i haven't had a problem.
Old Jun 23, 2010 | 01:48 PM
UMI Sales's Avatar
Tony.
Hello Tony
Thanks for suggesting UMI Performance! We do offer a weld on SFC that will tie the weakest points of the frame together. Below is a link to show you what I am explaining. The only issue that may occur is if you have duel cats on the exhaust (there might be a clearance issue). And below at the bottom of the ad is the install pics so you can see how they look.
http://www.umiperformance.com/catalo...m6frm4l3eubdc4
If you have any other questions feel free to ask!
Brad
Old Jun 23, 2010 | 01:50 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
yes both is better.... i have pics of bmr and alstons welded on mine.... look for alstons and bmr subframe connectors with pictures... or something like that.... i have a hard top but both set are really worth it... i did the bmrs first.... they added noticeable stiffness and reduced squeaks and rattles..... then adding alstons stiffened it even more reducing even more rattles.... the car feels so solid and it feels excellent.....
Old Jun 23, 2010 | 02:09 PM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
88fastgta- i just seen ur subframe connectors is that what some ppl call inner and outter sub frame connectors? thats actul pretty smart idea i may look into doin both on my car.
my car dosent even have cats on it so i wont have to worry about clearnace problem.
Old Jun 23, 2010 | 02:17 PM
88fastgta's Avatar
Yes that's what we cann inner and outer frame connectors...... The alstons were close to 200 and the bmr were about 250.... Plus 100 to weld them.... But they are definitely worth it... Also get a strut tower brace and a wonderbar to really stiffen it all up.... Juwt make sure you put them on with the suspension fully loaded, meaning all four tires on the ground.....
Old Jun 24, 2010 | 07:14 PM
As 88fastgta stated, his alston/BMR setup is an inner (alston) and outer (bmr) combination of subframe connectors. He felt a difference in his hard top with one, and even more with the other one, so with your t-tops you will SURELY feel a great difference I can assure you. Off the top of my head these are the brands (in no order of quality):
inner:
MAC
ALSTON
HOTCHKISS
outer:
SPOHN
UMI
BMR
Old Jun 25, 2010 | 12:01 AM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
wicked thanks for the info< now would it be a good idea to installed the subframe connectors first, cuase i need to replace the frt foot floor pan its rusted out, i figer do the subframe connectors firsts to stiffen the chassis.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
RS Reaper
Sep 27, 2015 07:04 PM
mfp189
Sep 27, 2015 09:25 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
