possible to upgrade calipers on a 91z with stock size rotors?
my car has acdelco performance cross drilled and slotted rotors on it and i was wondering if i could upgrade my calipers as well......the rotors are stock size, just built better than stock.
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Not unless you upgrade your brakes to the 1LE kit (or one of the Baer Racing kits). You can get better brake pads for your stock calipers, which would make a world of a difference.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
yeah i've done all of that, and the car stops so well that i don't see the need for a better settup, i don't road race it so it's definately not a problem, i merely wanted to see if i could get if anything a better looking set of calipers more race oriented i guess. i'm begining to find out that this isn't possible though.
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Only larger diameter rotors,and matching calipers will help.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
as wonderful as that sounds, larger rotors aren't necessary for the street, just changing these rotors from stock have made a huge improvement, i will have to put some skid pad times down for those who really care....anyway, i could care less to spend $2 grand more to have an inch and a half more diameter.........i'm not road racing the thing and that's an extreme cost for looks!
thanks for all the posts guys
thanks for all the posts guys Thread
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
