Strut mount install without taking off strut?
Old Mar 30, 2001 | 11:33 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
Can I just jack the front of the car, take the wheels off and then take the strut mount off and put the new one on? I know I will have to hold the strut so that it doesn't flp around after I take the mount off but will this work or am I over looking something?
'89 Formula 383 TPI
Old Mar 30, 2001 | 12:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sounds good to me! A problem might present itself if the strut extends up too high, and doesn't let you get the new mount to seat onto the strut tower. If you use an awl to scratch around the base of the current upper strut mount, you could re-install the new one in the exact old position, and save yourself an alignment. (That is, unless your car needs an alignment anyway!)
Make sure you raise the car by the crossmember, not the a-arms.. but sounds like you knew that already
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 30, 2001 | 01:15 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i put on new strut mounts last summer and although your idea sounds good, i dont think it would work but i would also say you can try it and let us know if it works
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , aftermarket LCA,s and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
Old Mar 31, 2001 | 03:27 PM
82camaro's Avatar
Car: 82 camaro SC
You might need a jack stand under the control arm. The strut/strut mount stops the spring from extending itself all the way and popping out
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 31, 2001 | 08:07 PM
Greg's Avatar
I replaced the struts about 3 years ago and the spring stays compressed even after the strut has been removed. For some reason the control arm doesn't lower enough to let the spring pop out. You would need to get a spring compresser to get the spring off these cars.
'89 Formula 383 TPI
Old Apr 1, 2001 | 06:50 PM
Greg's Avatar
It was super easy guys. All I had to do was mark the old position jack the car up, take off strut nut and the three holding the mount on and switch it out. It took like 15 minutes per side. It was easier than doing the wonderbar!! Piece of cake.
'89 Formula 383 TPI
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
